Ethanol fuel is leaner burning than the fuel the H was born for. The load adjustment might be turned out a little to see if it will help. Low float level can also provide lean condition, (but you checked that). The fuel flow needs to be a solid stream running for at least a minute. There is also a screen in the fitting at the carb. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
