Posted by KENIND on January 23, 2015 at 03:49:54 from (199.189.61.37):
In Reply to: spark plugs posted by William Eccles - Jardine on January 21, 2015 at 15:42:42:
I have run the same set of Champions in my H, M, for over 2 years. I have the same plugs in my 2 Case DC's for over a year and never had a problem with them . I run D21's in them for easier starting. If Im going to plow all day I will put a set of d14's in the M just because that's what Dad always did. Good Luck......Kenny :D
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
