Re: farmall 200 hydralics
Posted by IH fan on January 23, 2015 at 06:23:32 from (68.103.185.25):
In Reply to: farmall 200 hydralics posted by dewy on January 23, 2015 at 05:59:08:
For not picking it up, sounds like maybe the relief valve is low. Best way to check that is with a pressure gauge to see if it's set as high as the one that will pick up more weight.
If I'm not mistaken, that block is a "pilot operated check valve", meaning if you pressure it one way, it opens the return on the other side so the flow will return. Meant to help lock an implement in position and not leak down even if the main valve leaks a little.
