need advise on crankshaft removal on 10 20
Posted by Ron Ohio on January 11, 2001 at 15:22:52 from (152.163.204.77):
Thanks for helping me get the flywheel off. Now I'm stuck on how to get the crank out. Have the flywheel off and the bearing cap behind it off. Also I have the cam, oil pump and pistons out. The only thing left on the crank is the front, cam driving gear and the two main crank bearings front and rear. I think I understand it comes out from the rear in one piece. Do I need a special puller or do some of you have a homemade method? Do I have to pull the front gear first? I'll soon have this apart and then can give you all a rest until I start putting it back together. Thanks for any help. Ron
Post A Followup
: Re: need advise on crankshaft removal on 10 20
