Re: Farmall 706 FH to 3-ph
Posted by tjv on January 23, 2015 at 19:38:34 from (67.230.241.17):
In Reply to: Farmall 706 FH to 3-ph posted by leeedwin9 on January 23, 2015 at 11:54:05:
one thing you will have to do is take the arms off the rockshaft and turn them a few splines to get the 3 point to lift high enough I believe there is an index mark on the shaft for3 pt and another for fasthitch just adjust accordingly,
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
