Re: Ever break sleeve on start up after O/H?
Posted by SDE on January 24, 2015 at 07:02:31 from (207.118.213.76):
In Reply to: Ever break sleeve on start up after O/H? posted by Mitch D on January 24, 2015 at 06:10:59:
Is it possible that you have the connecting rod attached, facing the wrong direction? Is the rod cap facing the same direction as the others? You may have the piston facing the correct direction, but if the piston was installed on the rod facing the wrong direction, then the rod would be in wrong. Just a guess. I did that on a V-6 but caught the mistake before I started it.
SDE
  Upload Photo  Select Gallery Photo  Attach Serial No List
