Re: Ever break sleeve on start up after O/H?
Posted by The tractor vet on January 24, 2015 at 09:47:59 from (104.179.81.68):
In Reply to: Ever break sleeve on start up after O/H? posted by Mitch D on January 24, 2015 at 06:10:59:
Well if they PUSHED in then there is your problem as you DID NOT READ the bore class stamped on the deck of the block and you bought a off the shelf rebuild kit and they ONLY Fit bore class A & B not C & D .
  Upload Photo  Select Gallery Photo  Attach Serial No List
