Posted by lfure on January 24, 2015 at 14:43:43 from (68.169.254.14):
In Reply to: spark plugs posted by TXZane on January 21, 2015 at 15:42:42:
NGK plugs are a product of Japan. The first time I ever came across them was in Japanese motorcycles. They are a good quality plug though. The tractors I have trouble with fouling I use NGK plugs. Anything else gets AC plugs. For some reason I have had trouble with Champion plugs. They were never a problem 30-40 years ago, but something has changed since then.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
