Sound like the spark is getting weak when the alternator is cut in.
Try running a jumper wire from the battery + post to the hot (ignition switch) side of the coil. Now run the engine and see if it runs smoothly when the alternator is charging.
If it does look for an incorrectly wired ignition switch or alternator control circuit wiring.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
