Re: cub spitting and sputtering
Posted by Janicholson on January 24, 2015 at 18:08:16 from (74.60.94.18):
In Reply to: Re: cub spitting and sputtering posted by jsfarmall on January 24, 2015 at 16:41:17:
The alternator should work that way, But if it is failing it can make problems for the ignition. The best practice is to have the alternator checked by a real Auto Electric store/shop. Not a high volume parts store. If you are still concerned, try this test. Hook up a separate battery to the ignition coil/ballast resistor and then start the engine with the normal ignition turned off, and then start the alternator. If it stays smooth, replace the alternator. Assuming it is a Delco 10SI alternator, the terminals will be BAT, 1 and 2. Bat to amp meter load side, #2 to Bat, and #1 to a idiot lamp (marker light Not LED) then to the ignition coil supply from the on off switch. (assumes it is coil and points, not a Mag. If a mag, no connection can be made from alt to mag. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
