Re: cub spitting and sputtering
Posted by Cory Schmidt on January 25, 2015 at 08:28:37 from (64.246.253.39):
In Reply to: Re: cub spitting and sputtering posted by jsfarmall on January 25, 2015 at 04:16:27:
Maybe at the higher RPM the alternator has enough output that it back feeds through various paths that it shouldn't. Where at the lower RPMS the output is to low to cause a noticeable problem. All I know is electricity is force that goes by path of least resistance from source to ground. If that path happens to be feeding through ign. system it will go there, possibly causing problems with spark. I may be wrong, someone will correct me, we all learn.
  Upload Photo  Select Gallery Photo  Attach Serial No List
