Posted by Janicholson on January 25, 2015 at 15:20:35 from (74.60.94.18):
In Reply to: Follow-up on 706G posted by WI Dave on January 25, 2015 at 13:15:39:
Though probably a good deal, the TA is out. The hydraulic TA, when the lever is back, is dependent on a sprag clutch to prevent the body of the unit from turning backwards. With this TA there is a hydraulic clutch that prevents free wheeling down hills, it is not powerful enough to hold the engine power, and never was. The direct drive is also hydraulic. It is a much stronger and robust clutch. It can handle engine power, as applied through the TA. If the Hydraulic (MCV) system were toast, the tractor would only move in TA, not direct, and then, with the sprag clutch failing, it might not move at all. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
