Re: Ever break sleeve on start up after O/H?
Posted by BoonvilleKid on January 25, 2015 at 18:22:02 from (72.47.42.253):
In Reply to: Ever break sleeve on start up after O/H? posted by Mitch D on January 24, 2015 at 06:10:59:
For what it's worth the IH SC Service Manual states: "When furnished as service parts, the cylinder sleeves cannot be obtained separately but only in combination with matched pistons. When installing a new set of sleeves and pistons, do not interchange the pistons and sleeves or the piston pins, between the pistons." They indicate that on wet sleeves the rubber rings are to be installed first and then the outside of the sleeve coated with soap solution. They mention: "Insert the cylinder sleeves into the crankcase and HAND PUSH them into position. If the rubber sealing ring is accurately installed and not pinched, the sleeve should enter easily into its position."
I have no idea if it really works that easily or this instruction applies to other models.
  Upload Photo  Select Gallery Photo  Attach Serial No List
