Re: I need new bearings for my Farmall 300 T/A
Posted by D Slater on January 26, 2015 at 09:41:03 from (184.14.164.167):
In Reply to: I need new bearings for my Farmall 300 T/A posted by Oster on January 25, 2015 at 20:34:31:
Never able to find the MU 5206 or IH number 53323DA bearing for under sixty some dollars. Around $90 at dealer. Not a common bearing and needs special ordered at a lot of places. 359955R91 needle bearing that goes up inside the input or sun shaft is not bad at a dealer. around 11 bucks.
Think any hy capacity dealer can get t/a parts. They used to sell the needle bearing and other parts when I worked on them.
Don't know if this is still true. But at one time if you needed to buy all the T/A needle bearings, planet shafts, machined ramp and rollers, have to pay for the machine work on carrier, new seal and have to pay retail for parts you are looking close to the price of a complete rebuilt unit. If the sun shaft, transmission input shaft out of the T/A, planet gears or planet gear thrust plates need replaced you sure will be up or over a unit price.
Best to get part numbers then check on line anytime you need parts for old tractors, then call around if needed.
Example last month I needed a gasket set that mast places want 120 to 160 for. Found same gasket set in unopened box for 49 bucks.
Agree with others Steel W.R. is okay
  Upload Photo  Select Gallery Photo  Attach Serial No List
