Re: 404 International starter drive
Posted by mkirsch on January 26, 2015 at 12:18:44 from (72.45.143.81):
In Reply to: 404 International starter drive posted by C135 Rick on January 26, 2015 at 09:29:05:
I assume you got the new flywheel to avoid changing the ring gear?
If there was nothing else wrong with the original flywheel, replacing the ring gear isn't that bad. All you need to do is cut the old one off with a torch or angle grinder. Put the new one in the oven, get it to about 300 degrees or so, and drop it over the flywheel. New ring gear, new starter drive, you'll be set for life.
