Re: 1951 Super C Rear Axle
Posted by Janicholson on January 27, 2015 at 09:30:30 from (199.17.6.26):
In Reply to: Re: 1951 Super C Rear Axle posted by DeltaRed on January 27, 2015 at 07:58:10:
In addition, to the correct length housing, a common solution is to mearly cut the long axle to length and clean the cut to look "made that way".
The long axle is however valuable long to others. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
