My guess is that somewhere in the life of the donor tractor it had the ring gear replaced and it was replaced with the gear that was used on tractors up until the 404 series. If the ring gear is not in like new condition you can assume that the tractor was run with that ring gear not causing problems.
Check the tooth engagement of your drive in the replacement ring gear. It will most likely work just fine as long as the ODs of the ring gear is the same. The tooth engagement is pretty loose between the drive and ring gear and it s not uncommon to find a couple drives with different amount of teeth being used on the same ring gear. That is the case of drive number 1939109. That is a 9 tooth drive that was replaced with a drive with 10 teeth during the production run of the 656 tractors. There was no change in ring gear when the drive was changed on those tractors.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
