Yes. if the material on the disks is nearly as good as new (ask for the thickness of the new disks, I do not know off hand) the total clearance should be .040 to .060", measured by putting the components into the housing in order, and measuring across the housing down to the first disk. A non-directional sanding with 200 grit paper will break the glaze. clean the ramps and balls. dry PTFE (Like Try-Flow) can be used there (just a little) on the balls and ramps. The housing needs to be machined at the surface where it mates with the tractor to reduce clearance. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
