Posted by Owen Aaland on January 27, 2015 at 23:16:14 from (216.47.34.37):
In Reply to: 1951 Super C Rear Axle posted by Larry Hardesty on January 27, 2015 at 07:44:31:
If all you are doing is replacing the axle it can be done by removing the wheel from the axle. Remove the axle housing end cap. Remove the PTO assembly or block off cover. Remove the two cap screws that hold the ring gear on the axle. Pull the axle out of the bull gear and inner bearing. The outer bearing will come out with the axle. If you are going to replace the inner oil seal you will also have to remove the axle housing to gain access to the bearing and seal.
Newer replacement axles used a snap ring to hold the bull gear onto the axle rather than the two cap screws and washer plate.
Axles came in three different lengths. There were 80", 88" and 100" tread width axles listed in the parts book. There is also a different axle housing listed for use with the 100" axles versus the 80" or 88" axles.
This post was edited by Owen Aaland at 23:16:48 01/27/15.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
