Re: Super a touch control help
Posted by Jim Becker on January 28, 2015 at 14:19:15 from (173.84.243.159):
In Reply to: Super a touch control help posted by sony224422 on January 27, 2015 at 18:29:09:
Those are 2-way valves and do not appear to be power beyond (some can be converted with additional parts, but no evidence of such with these). One of these valves could be plumbed to work but possibly with some odd side effects. Any added valve connected where your looped hose (toilet hose) is will have its own lever and that lever will be the operating control for any attached cylinder.
To use the Touch-Control levers, you must connect whatever implement to the Touch-Control rockshaft. That is the way your A-60 blade is intended to work. What is missing from your A-60 blade? If you can provide pictures of all the pieces you have, we may be able to determine exactly what is missing. That may be the simplest and least expensive way for you to push snow.
