Re: Farmall H distributor and electronic ignition
Posted by jsfarmall on January 28, 2015 at 18:43:23 from (162.104.79.110):
In Reply to: Farmall H distributor and electronic ignition posted by 2249helmkamp on January 27, 2015 at 17:15:07:
Avgas is probably cause its around 110 octane or higher. After gas sits it loses octane rating. If gas loses 15 points in 6 months then avgas is still 95 at least and 87 is now 72. Also avgas is higher quality fuel anyway. Airplanes tend to sit a while in the private sector of aviation so they also take that into consideration when processing. Personally with me I'll buy a jug of stay bill. But to each is own. I never thought about it but that's actually a good idea if its mainly a show tractor that don't work and has very little fuel run through it.
  Upload Photo  Select Gallery Photo  Attach Serial No List
