Re: Farmall a rear weights how many?
Posted by gene bender on January 28, 2015 at 21:13:58 from (67.55.226.121):
In Reply to: Farmall a rear weights how many? posted by Onedeere37 on January 28, 2015 at 18:28:55:
Yes you can put one on the inside of the center section then two on the outside and if you wanted more get another cast center section like on the drivers side. That would be around 600lbs on each wheel should be plenty of wt then.
  Upload Photo  Select Gallery Photo  Attach Serial No List
