Re: Super a touch control help
Posted by WellWorn on January 28, 2015 at 21:46:53 from (75.228.126.30):
In Reply to: Super a touch control help posted by sony224422 on January 27, 2015 at 18:29:09:
Sony, here's a picture of the assembled plow unit on my SA.
third party image
You seem to be missing most of the lift mechanism. There is a long 3/4" bolt with square washers and a spacer tube that goes through the square tube of the front bolster (nut visible just behind the front axle) that holds the '3 legged bracket' in your picture; a plate that bolts to the bell housing, and the tubular rod that connects from the plate that pins to the rockshaft (needs 2 pins).
Hope that helps.
BTW, the ~240# of weights on the blade frame don't really belong there, nor can I say what they are counter balancing, lest I be turned in to the SPCT.
This post was edited by WellWorn at 21:49:57 01/28/15.
