All 3 ports have pressure out and fluid return through the same ports. Only can use with single acting cylinders unless another valve is added to the system. If hooking to a single acting cylinder on each side of tractor, use the right and front left port. Left rear port has a separate check to open when lowering. Pull rod back to get pressure and push forward to lower. Yes that's the fill cap. If its still there it will have a fluid level dipstick under it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
