Re: Connect battery wrong
Posted by john *.?-!.* cub owner on January 29, 2015 at 08:12:18 from (99.195.119.153):
In Reply to: Connect battery wrong posted by Larry Hardesty on January 29, 2015 at 07:51:33:
Use a test light or voltmeter to see if you have voltage at the terminal on the starter when trying to start it. If not, keep working back toward the battery till you find the problem. May just need to remove the battery terminals and clean the connections, or maybe the ground end.
