Re: Connect battery wrong
Posted by mkirsch on January 29, 2015 at 12:05:04 from (72.45.143.81):
In Reply to: Connect battery wrong posted by Larry Hardesty on January 29, 2015 at 07:51:33:
The ammeter has nothing to do with the starter. All the power for the starter goes through the thick cables.
If it won't even crank, you've got a bad connection on the thick cables somewhere.
