Re: Connect battery wrong
Posted by old on January 29, 2015 at 13:32:39 from (72.251.71.108):
In Reply to: Re: Connect battery wrong posted by Larry Hardesty on January 29, 2015 at 12:26:07:
Alternator went the moment you hooked it up back wards. Only take a split second to fry an alternator. By the way very likely that it being bad will drain a battery in short order so unhook the big lead off the alternator or your likely to have a dead battery in an hour or less
  Upload Photo  Select Gallery Photo  Attach Serial No List
