Re: voltmeter vs. amp meter
Posted by Bob M on January 30, 2015 at 07:15:43 from (67.240.163.172):
In Reply to: voltmeter vs. amp meter posted by bass on January 30, 2015 at 04:57:41:
mkirsch's method will work. But it has the voltmeter energized continuously. Not a problem if you run the tractor every few days. However depending on the resistance of the voltmeter, it will drain the battery if left unstarted for a couple weeks/months.
Preferred is to wire the voltmeter so it's energized only when the ign switch is "on":
1 - Remove the wires from both ammeter posts and connect all them together. Thoroughly tape/insulate the connection!
2 - Connect the + voltmeter terminal to the switched (coil) side of the ignition switch.
Connect the - terminal to a GOOD ground.
  Upload Photo  Select Gallery Photo  Attach Serial No List
