Posted by Janicholson on January 30, 2015 at 17:24:28 from (74.60.94.18):
In Reply to: TA troubles posted by ihjason on January 30, 2015 at 16:33:15:
More than likely Both are in need. The trans is probably in two gears at once. Pretty easy to fix by removing the shifter lever, and moving the slots back into the neutral center position. Yje TA probably needs that sprag clutch. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
