Re: TA troubles
Posted by ihjason on January 30, 2015 at 18:13:04 from (207.191.145.131):
In Reply to: TA troubles posted by ihjason on January 30, 2015 at 16:33:15:
When it went out I did pull it home in neutral. So I don't think it is stuck in two gears. I will double check that though. I am getting ready to take it apart and didn't want to take any more apart than I had to. Thanks for your advice and answers.
  Upload Photo  Select Gallery Photo  Attach Serial No List
