Re: TA troubles
Posted by pete 23 on January 30, 2015 at 18:55:41 from (173.87.144.45):
In Reply to: TA troubles posted by ihjason on January 30, 2015 at 16:33:15:
Just a guess here, sprag rolled over and now works in opposite direction as if installed backwards. Can check by pulling small cover over ta, pull ta lever back, block clutch down and carrier is supposed to rotate in direction of engine rotation. If it goes opposite way, sprag has turned over. Never seen this in one of those TA's but a sprag would turn over in the hydraulic TA's and then get torn up and not work at all in TA.
  Upload Photo  Select Gallery Photo  Attach Serial No List
