Your mower is a No 16-HM. The A-21 and C-21 mowers had completely different drawbars. The A-21 drawbar was attached to plates which were bolted the inner sides of the final drive housings. On the C-21, of which I have one that I use on my Super C, the drawbar is clamped directly onto the hexagonal axle housings. I note in your photos that the drawbar braces are a bit mangled. I also note that the mower probably had connections to a Lift-All cylinder for raising the cutter bar. Hope this helps. Sid.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
