Posted by Bishop64 on January 31, 2015 at 04:36:53 from (67.142.182.23):
My dad's 806 power steering acts up in the winter. In the past it seems to be due to moisture in the system and iced up filter (common from what I've read here). Operates fine in the summer batwinging, etc. Usually the issues will "go away" once the tractor is warmed up and the steering cycled for a while.
Putting out hay the other day it started acting up again and the transmission would cut in & out too, which is new. From what I can read it sounds like the first step is overfilling by 5 gallons after I replace the filter again and drain any water out of the bottom. If that doesn't work we'll dive into the pump.
Am I approaching this in the correct order?
Tractor has a front end loader and to be honest, it was dark when I was messing with it and could not really tell the hydraulic level. I'll check that first while it's cold.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
