Re: IH 340 Utility Power Steering.
Posted by Janicholson on January 31, 2015 at 08:34:42 from (74.60.94.18):
In Reply to: IH 340 Utility Power Steering. posted by lfure on January 31, 2015 at 07:07:04:
If the steering spindles have not been serviced, it will be hard to steer. They must be at least lifted from the ground and greased until grease is evident at the bottom thrust flange. If it will not grease properly, taking them/it apart is the only answer. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
