The issue with the originals was the acid fumes from the battery box coupled with being exposed to the elements, and lack of paint on the surrounding surfaces, they tended to rust & begin to pit on the inside & underneath.
Many I have found were once "fixed" by brazing the pin holes closed, seems you were always "chasing" a small pesky permanent leak prior to painting. The best way was take them to someone very talented in welding steel lines, and have them pressure tested as well. See aircraft tubing repair......$$$$$$.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
