Posted by 87nassaublue on February 01, 2015 at 05:27:09 from (216.130.146.218):
In Reply to: 966 oil pressure posted by big farmer on January 31, 2015 at 16:04:03:
Basically, what you're seeing is the pressure drops when the oil is at running temperature and thins down. You see the variance in pressure because there is at least one bearing somewhere in the engine that has a greater clearance than you'd like it to have. 15 lbs at idle with the engine warm is not that bad. I wouldn't worry too much about it if it's running good. You can try running a higher viscosity oil if it's bothering you.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
