Re: Farmall B Leaking gas at carb????? Very frustraited!!!!!
Posted by old on February 01, 2015 at 10:51:19 from (209.86.226.40):
In Reply to: Re: Farmall B Leaking gas at carb????? Very frustraited!!!!! posted by rjc2rjc on February 01, 2015 at 10:22:56:
Still 6 volts or is it now 12 volts can make a difference as how to fix it?? Things to try
#1 turn the gas on count to say 20 then turn it back off and try to start it. If it starts quickly turn the gas back on
#2 check the spark. It needs to be a blue/white in color and jump a 1/4 inch gap or more.
#3 pull the starter and have it check to make sure it is in fact good and not dragging or pulling to many amps so as to rob the spark of power.
#4 when is the last time you serviced the oil bath air cleaner
  Upload Photo  Select Gallery Photo  Attach Serial No List
