Re: Farmall B Leaking gas at carb????? Very frustraited!!!!!!!!!
Posted by Notjustair on February 01, 2015 at 10:58:43 from (70.195.0.35):
In Reply to: Farmall B Leaking gas at carb????? Very frustraited!!!!!!!!! posted by rjc2rjc on February 01, 2015 at 09:59:38:
My M does that if it is very cold and I give it choke to start with.
They don't usually need choke to start, but may need it to keep
running when very cold. The battery I have in it doesn't have a
lot of CCA so it spins slow. I think you are fine. Adjust it two
turns out to get it to start and go from there. If you don't have
the air cleaner hose on it put your fingers over the inlet of the
carb restricting it a little bit to get it to draw in the fuel. Don't
run over yourself!
  Upload Photo  Select Gallery Photo  Attach Serial No List
