While you have the starter off being tested and probably for some refurbishment get some new battery cables made up at a good auto parts place. I have found using 00 size cable and soldered terminals have fixed starting problems on all of my 6 volt letter series Farmalls. Attach the ground cable to one of the starter mounting bolts making sure you have very clean and bright connecting surfaces and hardware. Keep the cables as short as possible with enough length for easy connections. Same thing for the cables to the starter motor. I also generally use external tooth washers at the non-battery connections to get an extra good bite into the metal or contact surfaces. I don't recall if you have a 6 or 12 volt system but this is really needed for the original 6 volt systems, Hal.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
