Re: Farmall B Leaking gas at carb????? Very frustraited!!!!!!!!!
Posted by jsfarmall on February 01, 2015 at 17:58:28 from (184.159.233.160):
In Reply to: Farmall B Leaking gas at carb????? Very frustraited!!!!!!!!! posted by rjc2rjc on February 01, 2015 at 09:59:38:
Well both of my farmall being an h and
cub, leak when shut down. When the engine
fires the leak immediately stops. Even
rebuilt carb on the cub because it leaked.
No change at all. Any farmall I seen
changed to 12v will sure spin the engine
if everything is right. Gotta be careful
sometimes though so not to burn up that 6v
starter.
  Upload Photo  Select Gallery Photo  Attach Serial No List
