Re: Farmall B Leaking gas at carb????? Very frustraited!!!!!!!!!
Posted by Paul from MI on February 01, 2015 at 20:29:44 from (68.43.113.193):
In Reply to: Farmall B Leaking gas at carb????? Very frustraited!!!!!!!!! posted by rjc2rjc on February 01, 2015 at 09:59:38:
Some of the overhaul kits that I have used, especially NAPA, do not have the bowl vent hole punched in the gaskets, which will cause the bowl to overflow when the engine is not running. I've found this same problem several times. Carefully check your gasket against the carb body to be sure the vent isn't plugged.
  Upload Photo  Select Gallery Photo  Attach Serial No List
