Easy just remove the diff housing . Then you will need to remove the brake drum on the diff shaft and plate on the outside of the final drive so the shaft can come out of the final. Install the As drive shaft and then brake drum and then the final can be bolted back to the BNs tranny. Makes a nice set-up for a mower as the rim and tire can be spaced for which width you like. I add a wt to the inside of the center section. Ive done it several times for mowing.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
