Re: Farmall A governor/throttle linkage help
Posted by Brownie450 on February 02, 2015 at 14:34:18 from (66.43.241.198):
In Reply to: Farmall A governor/throttle linkage help posted by Kevin on February 01, 2015 at 10:39:03:
The other person might have added that spring just to keep any looseness out of the linkage. As Gene says---doesn't need to be there.
If it doesn't idle down correctly after all adjustments are made---a last thing to try is look to see if the throttle plate is on right side up.
Our SMTA wouldn't idle down, & the mechanic got the throttle plate in upside down.
  Upload Photo  Select Gallery Photo  Attach Serial No List
