Re: moisture in engine oil?
Posted by old on February 02, 2015 at 14:53:13 from (209.86.226.30):
In Reply to: moisture in engine oil? posted by jsfarmall on February 02, 2015 at 14:41:32:
Condensation can cause that. Easy way to check islet it sit a few days then do not start it but slowly open up the drain plug and do so just enough to get it to start dripping. If just water you should get a water drip. If it is antifreeze it should be green in color. Either way that will help you figure it out and also get the water out of the oil
  Upload Photo  Select Gallery Photo  Attach Serial No List
