Re: Did IH use ID tags on prototypes?
Posted by D Slater on February 02, 2015 at 15:59:45 from (184.14.187.78):
In Reply to: Re: Did IH use ID tags on prototypes? posted by biggerred on February 02, 2015 at 13:17:01:
Correction that said GAS POWER ENG. DEPT.
TRACTOR WORKS. May not be able to see it in the picture I posted but its interesting that the steering shaft appears to have a coupling near the radiator, Block casting number is near front instead of rear like most, throttle linkage is different and the rocker arms look like ones used on later tractors and not like early ones. If vent pipe openings are in the top side of head they are not visual. Can see the front opening.
  Upload Photo  Select Gallery Photo  Attach Serial No List
