Re: Farmall A convertion to 12V negative ground
Posted by Bob on February 02, 2015 at 18:35:36 from (64.255.159.192):
In Reply to: Re: Farmall A convertion to 12V negative ground posted by dhabeck on February 02, 2015 at 18:12:50:
The "wire coming out of the distributor part", in this case, is the screw terminal to which you have correctly attached the primary wire from the coil.
  Upload Photo  Select Gallery Photo  Attach Serial No List
