Re: Farmall A convertion to 12V negative ground
Posted by Bob on February 02, 2015 at 18:40:51 from (64.255.159.192):
In Reply to: Re: Farmall A convertion to 12V negative ground posted by dhabeck on February 02, 2015 at 18:38:38:
Take the upper bakelite coil cover off, and find the two coil primary wires. One was originally grounded, and the other went over to the condenser. The lead going to the condenser should be disconnected (or even cut).
  Upload Photo  Select Gallery Photo  Attach Serial No List
