Re: Farmall A convertion to 12V negative ground
Posted by Janicholson on February 02, 2015 at 20:55:42 from (74.60.94.18):
In Reply to: Re: Farmall A convertion to 12V negative ground posted by dhabeck on February 02, 2015 at 20:13:33:
Coils do not have internal resistors (there are examples, but not normal parts store reality) 12v coils are just wound with more and finer wire to run on the 14.2 volts normally found in 12v systema when running. If yours is marked "no external resistor required, it should have about 3.5 to 5 ohms of resistence ((disconnected from the points)
if lower, like 2.5 ohms or so, it is in need of a resistor. A 66 chevy ballast resistor will be fine. Wire it into the supply side of the coil from the ignition switch. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
