Re: Adding a remote to Super C and also, speeding up the hyd
Posted by mkirsch on February 03, 2015 at 05:30:56 from (72.45.143.81):
In Reply to: Adding a remote to Super C and also, speeding up the hydraul posted by schultz on February 02, 2015 at 17:07:49:
There is a "bypass block" that bolts between the touch control block and the hydraulic lines, which allows you to add as many remotes to the tractor as you want.
Normally it is used with the regular hydraulic lines. I am not sure if it will work with the fast hitch valve.
You could block the fast hitch in a fixed position and use its valve to control a hydraulic angle on the blade.
