Re: farmall C- 133 cu. in. carb. ?
Posted by old on February 04, 2015 at 09:18:19 from (209.86.226.58):
In Reply to: farmall C- 133 cu. in. carb. ? posted by showdown on February 04, 2015 at 07:18:47:
With out doing things inside the engine a larger carb will not help much if any at all. Now if the carb you have does not have an adjustable main jet then going to a bigger jet may get you a bit more but probably not enough to make a difference
  Upload Photo  Select Gallery Photo  Attach Serial No List
